1 members (1955 1 Series),
131
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 36 New Guy | | New Guy Joined: Jul 2012 Posts: 36 | Hello all. Just joined and already have questions (which is really why I joined).
I've got a 66 C10 and the lights are becoming like a Christmas Light nightmare. Only the headlights and the left turn signal/brake light worked when I got it. The wiring was a mess. At this point, I have everything working except the right turn signal and brake light. I was told when I baught the truck that it probably needed a new turn signal switch, as this was the explanation for the right signal not working. So, my question is this; would the problem with the turn signal switch also affect the brake light on the same side?
I know that it is not a problem with the socket (rear) as it works when I jump the wires to the left side. This is where I am stumped. Any ideas?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Yes. The brake lights feed through the turn switch. Use a test light & make sure there is no curent from the switch to the right rear light. You should have a wireing diagram. I think it is a green wire. That model particularly bad about that. I have taken off the strg wheel & the horse shoe & adjusted the contact springs but it is kind of a tedious job. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2012 Posts: 36 New Guy | | New Guy Joined: Jul 2012 Posts: 36 | Thanks for the feedback. I'll give that a shot. You are right about green.
Thanks again. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Also make sure you are getting a good ground. | | | | | Joined: Jul 2012 Posts: 36 New Guy | | New Guy Joined: Jul 2012 Posts: 36 | I added grounding straps all around the other day, so I'm still thinking it's the switch. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | There MAY be a body connector somewhere on the firewall that has the rear lighting harness running to/from it. I'd check and see. If so, it is the best place to check the condition of the entire rear harness. Also there is a big connector that connects the turn signal assy to the harness. Find the dark green wire on the left hand and check there. The light green going to the rear is the back-up lights. The Right turn/brake is the dark green one, and the left is yellow. All other rear lights are on the brown lead. It goes without saying to double check your grounds to the frame!
best wishes,
Les | | | | | Joined: Jul 2012 Posts: 36 New Guy | | New Guy Joined: Jul 2012 Posts: 36 | New development - not of my doing. Yesterday, I was out driving the truck when I accidentally turned on the right turn signal - it worked, but not consistently and only on the rear. Still no brake light on that side.
The whole housing below the steering wheel moves, and if you push it a certain way, the right turn signal works. Got to crack it open and figure it out. | | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Check the wiring diagram for correct wire color codes.
Is this a 6 wire or 7 wire turn signal switch?
Is it a Chief or Arrow or Signal Stat switch?
Most use the Green and Yellow wire for the front turn signals only.
Some use the brown (Right turn/stop) and orange (Left turn/stop) for the rear Combo Stop/Turn lights. Older Chief used grey with color strips. Usually the red was power, on some it is stop fed to switch.
Best is to determine which switch you have then follow color codes to rewire turn signals and stop lights.
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | Almost forgot...is this a factory switch mounted in steering column?
Dumb me...forgot to ask important question.
| | | | | Joined: Jul 2012 Posts: 36 New Guy | | New Guy Joined: Jul 2012 Posts: 36 | It's a 7 wire switch (I believe) as the connector that comes from the column has 7 wires (4 on one connector, 3 on the other). I also believe that it is factory and is still in the column. The guy that sold it to me didn't seem to know much about it. What I do know is that I have a brown wire for tail lights, yellow for rear left turn/brake and dark green for rear right turn/brake. If I have the wiring in the front correct, it looks like blue is the front right turn signal. | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | It may be as simple as the signal arm can't get the switch all the way into position for right turn or make the brake contact. If you remove the steering wheel there are three screws that hold that hub tight. With that loose, there will be no end of electrical nightmares in the column. Every single replaceable part in there is available, too, in case you need 'em!
Best wishes,
Les | | |
