1 members (Peggy M),
304
Mod | | | Forums66 Topics128,159 Posts1,057,033 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 40 | when i use my r.h.turn signal it comes on and stays on.how can i make this go away and return to normal? | | | | | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | that lever you pushed up to turn it on, pull it back down when you are done making the turn.....
the cancel cam arm broke, you'll need to replace that part of the switch, or the whole switch. must remove steering wheel to get it out. | | | | | Joined: Oct 2010 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 40 | then why when i make a right turn does the lever return to the starting position? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | because something is broke .... you need to bite the bullet and take the assembly apart and see what's what, if the cancel assembly doesn't have a broken pin then maybe the switch is buggered - nobody here can see it
Boll | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Sometimes the corner of the cancelling cam, attached to the back of the steering wheel, will break off and the signal switch, inside the primary bonnet will not return to the resting position, which is the open position for the left & right signal light circuit. Check this, in addition to the suggestions stated above. | | | | | Joined: May 2010 Posts: 162 'Bolter | | 'Bolter Joined: May 2010 Posts: 162 | Mine just needed a small adjustment. Follow the cable to the little "box" towards the end of the column. Move the lever up & down and you will see how it works Its been a while but I remember moving the wire and the box in combination to get it right. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i'm not sure i understand. you said the right hand turn sig stays on, later you said it returns to normal position. if it stays green and doesn't blink i would check the hood connection. if it stays on and blinks one way but won't return to off, i would check the canceling cam as everyone has said. only one ear could be broken off of it. good luck!
