3 members (texas46, Otto Skorzeny, 55shaker), 178 guests, and 0 robots.
Topics128,100
Posts1,056,178
Members48,436
#874070 08/12/2012 1:24 AM
If i wanted to do an engine swap 305E V6 For a V8 ,,In my 64 GMC 3/4 ton K-Truck,4x4, will it bolt right in motor mts, bell housing.??? Any body know---- Thanks Gooch
The GMC 305 V6 engines are a different configuration, than their sbc counterparts and the motor mounts & frame-to-engine perches are different on the V6 engines, than their sbc counterparts. Additionally, the 4x4 frame-to-engine perches are different than the 2wd counterparts. You will need V8 frome-to-engine perches from a '63-'66 Chevy K10 or K20, if you want a direct bolt-in application. Otherwise, you are only limited to doing what your skills or pocketbook will allow.
