13 members (Otto Skorzeny, Gdads51, TUTS 59, Jon G, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,103 Posts1,056,183 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | ...click... from deves web site | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Sorry for the confusion, kept trying to paste my lengthy response and wouldn't accept it. I will try and shorten it. #1 and #6 piston reach TDC at the same time of different strokes. #1 on compression. #6 on exhaust. when baring the engine over observe valve opening and closing on #6 (valve rock). this means #1 on compression, now set valves and check timing with distributor. The same holds true for setting #6 valves, watch for valve rock on #1. The same holds true for #2 and #5 which come up to TDC together and so doe #3 and #4. If rocker shaft not installed then install push rods and observe, much more accurate.
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | OK thanks for all this info guys. I am going to print it all and head to the garage. Sounds a tad complicated but I will give it my best shot tomorrow
Rick 58 3600 4 on the floor
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | OK think i'm in serious trouble now. I didnt have a dowl or long enough srewdriver as mentioned so I used a straightened coat hangar. I thought i was at tdc of the #1 but I went to go a bit further and now I think it started to go down and now the coathangar is stuck in the $%#@*&% spark plug hole. Is it pinching on the side or what. Can I back up the moter by turning the fan counter clockwise HELP
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | I pulled really really really hard and it came out. Hope I didnt leave a piece inthere. Gone to look for wood dowel
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | OK either you guys are pretty good teachers or I am an exceptional student. The ol beast starts, runs and sounds pretty darn good. I set the measurements to .05 above as someone mentioned. on the in and ex. Oiling still a problem. No oil coming up to the rocker. I took out the small drain nut on the side and nothing happened. Then I took the head nut out and stuck a coat hangar in wiggled it abit then started it and oil came pouring out the side nut. I replaced the 2 nuts and tried again but still no oil to the rockers. What I dont understand is the head bolt seems to block the oil entrance into the oil tube. Am I making any sence
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Ok, while you guys were sleeping I did asearch and read some old files I think my problem is that the head bolt is suppose to have a groove on the side or be drilled up through the centre because oile comes up the head bolt hole when removed. I imagine this is why the rocker ar shaft broke in the first palce. Am I right about bolt and is it better to have a drilled one or somehow cut a groove in it? Thanks Rick
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | On a 1958 engine the oil path is up the center from the lifter galley to the bottom of the head bolt. Then it takes a right angle through a 1/16" orifice(most likely plugged on yours), then it turns up to the top of the block. Where it exits the top of the block there is a triangle opening in the head gasket. In this triangle is also the pass side center head bolt. Oil passes through this triangle over and up around this head bolt. Once the oil reaches the top of the head bolt it takes another right turn and goes over to the rocker connecter supply tube. See fig #15
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There is a plug under the side cover that gives you assess to the orifice. Hotrod's dowel and hammer trick will not work on your engine, only 1957 and earlier engines. You would need to try blowing back on the hole that the rocker supply tube fits in to on top of the head, or pull the side cover.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | gives you assess to the orifice. LOL! Freudian slip Dave?? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Hi I opened the unpinched the oil tube and stuck a coat hangar down it and it seems to be clear. What is the plug on the side of head for and what will happen or accomplish if i take the side cover off. Should I not have one of these drilled bolts? the oil seems to be at thre bottom of the head bolt
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If the orifice is plugged and you do not want to clean it a drilled head bolt would be another option. Drilled head bolt picture
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | How can I clean it and with what. Can you tell me if it is plugged above or below the head bolt
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Can you tell me if it is plugged above or below the head bolt See Fig #15 in above link I think the easiest thing for you to do is drill a head bolt.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | With the head bolt removed I sprayed some lube cleaner down the pinched oil tube and it came out into the head bolt shaft area. I started the engine and oil came up the hB shaft quickly. So where am I plugged Whe I put the HB in there is no oil. I am going to put the HB back in and leave the oil tube unpinched and see if it comes up the oil tube
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Starting to make some headway. Put HB back in and started motoor. Oil came up the unpinched tube for a while . Oil came out the first rocker on each side of the tube. Then the oil seemed to go the tube a bit and I repinched the tube. Oil came out 2 rockers on the front shaft and 2/3 on the back shaft
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Should be streaming out all rockers or is it a very minor drip out the top rocker holes
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Should it be streaming out all rockers or is it a very minor drip out the top rocker holes?
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | something like this ...click... | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | So is the oil suppose to come out the tiny holes on top of the rocker arm
| | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | OK thanks for the video.I see you should be able to see a steady stream comining out the hole. I am not getting that. But I am stumped cause it was coming up the tube. I dont seem to be getting any now
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Well I replaced the front rocker arm shaft. I bought a used one. and took off all the rocker arms springs etc and put my old ones back on. But forst I cleaned the heck out of the shaft and arms. I did not take the back shaft off
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All you need is a small drip.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Drilled the HB and struck oil Thanks everyone. You got me through something I thought was way beyond my scope Rick
| | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | Rick I was sorry to hear about your trouble with a piece of wire down the spark plug, I have no right to tell you 'I told you so'. But I must mention as a retired Diesel Mechanic, Marine Engineer, my training would not allow me such practise. A thumb or whistle in the spark plug hole would give you the same result, I'm sure that you have learned a valuable lesson here. Please remember some of my favourite expressions. 'the long way around is the shortest way home' and 'I'd rather be 10 minutes late in this life than 10 minutes early for the next'. Good luck with your project.
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Oct 2011 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 187 | Thanks Blanch, lucky for me it has all worked out. Thanks for your help and wisdaom Rick
