1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#87388 10/20/2003 5:07 AM
Junior Member
Junior Member
I am rewiring my 1950 Chevy 1/2 ton pickup and want to run the dome light wire from under the dash to the dome light at the upper rear of my truck. Do I run the wire up through the roof support brace? If so, what is the best way to locate a hole (if one exists) that I can do so? I have been using a hanger wire but could not find a hole. Any ideas? Thanks!
Richie West
#87389 10/20/2003 10:37 AM
Meredith55, Welcome to the Stovebolt cool
Keep playing with the hanger wire down through the left support brace, it does go through there smile
#87390 10/20/2003 7:52 PM
The best way is to twist and tape the new wire to the old and pull the new one through as you pull the old one out. Of course if the old one has been removed already or if rats have severed the wire, back to the poking wire method. A piano wire works better than a hanger wire.
#87391 10/21/2003 3:52 PM
Thanks guys. I used a wire hangar and eventually worked it through the hole. The hole seems to be on the outside edge of the cab roof support. After working the hangar through the hole, I used electrical tape and taped the wire to the hangar and pulled the hangar out. Worked great. Thanks!
#87392 10/21/2003 11:00 PM
Is the dome light switch suspose to work separate of the dash head light switch,or do the headlights have to been on in order for it to work?..thanks,,,,,Fred
Redryder pix
My Hotrod
#87393 10/21/2003 11:42 PM
Dome light is separate and on its own switch
Are you having problems with yours Fred?
(possibly the battery drain problem?)
#87394 10/22/2003 1:55 AM
Luke, thanks,,,I was just curious,, have not been able to get mine to work for a while,, have not checked the bulb yet,, just turned the switch off and on,,noticed the post and was just curious,,,,,Fred
Redryder pix
My Hotrod
#87395 10/22/2003 5:52 AM
sounds like somebody needs to call in a qualified electrician........
#87396 10/22/2003 3:20 PM
Dome lights are wired different as one side of the bulb has power all the time. the door pin switches ground the other side as well as the headlight switch, the dome light bulbs most times also have a dual contact base like an 1157 taillight bulb but with a single filament.
#87397 10/24/2003 9:20 PM
The dome light in my '50 had a dirty switch, a good cleaning made it work again. It's a nice light too, pretty bright.
Paint & Body Shop moderator
#87398 10/24/2003 10:04 PM
I may try that, I replaced the bulb although the old one looked ok,,did not help ,,the switch did not seem to work real smooth,,so maybe it needs a cleaning too....thanks...............Fred
Redryder pix
My Hotrod
#87399 10/25/2003 2:44 AM
Apprentice
Apprentice
The trick a fellow radio tech showed me is to use an old speedometer cable for a fish wire. If you twist it as you push it will snake its way through like magic. Push it through and then tape the wire to the end and pull back.
When I find out what I'm doing, I'll let you know if I'm in too deep.
