Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (Brewhog55, JW51, Jon G, Gib70, 1 invisible), 571 guests, and 1 robot.
Topics126,781
Posts1,039,301
Members48,100
Most Online2,175
Jul 21st, 2025
hey guys,
newbie kinda question, were do you get the parts to rebuild the front end on a 1949 chev 1.5 ton truck? (like factory new)the half ton stuff is everywhere...
thanks in advance
You'd be surprized what you can get at your local NAPA or big truck spring shop.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
mike thanks, i'll tomorrow smile
i forgot to ask, what is a big truck spring shop?
thanks agian
3B Offline
Hy dukedaddy, kingpin kit for models QJ, QK, RJ, RK, SJ, SK, TJ, and TK 1 1/2ton Napa p/n NCP2621161 $71.10, RockAuto Moog p/n 8207B $23.79. these kingpins are .921" in diameter by 5.125" long, hope that helps.
Duke,
Most big cities have spring and suspension repair shops that work on BIG trucks. They do springs, king pins and drive shafts etc., thay might be a source for you.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Hughesville, MD
3B Offline
Hy dukedaddy, firstly lets start with one thing at a time. This post was originally about front axle rebuild parts, if you now want to talk about engine/truck identification, please start another post about that. People will only see the front axle question when looking through the forums. About the information I posted, the two letter codes are truck model designations, these were used before the number series was introduced, they are all the models the kingpin repair kit fits, they are all 1 1/2 ton trucks I believe. Napa is a huge aftermarket parts supplier, and the p/n (part number) I posted is their identification number for the kingpin overhaul kit they stock. RockAuto is also an aftermarket parts supplier, and usually the cheapest supplier for most things, both are accessible on the internet. Hope that helps.
3B, yes- thank you that does help smile
And you are correct about starting another post... I was thinking more along the lines of a conversation that can flow from detailed topic to other items under the original umbrella of conversation. I will correct and will try to stay on topic. Thanks again I appreciate the feed back.
DD
guys i removed the post where i had asked about truck vin #s and truck ID. i did start a new post on that topic-
thanks 3B for guiding me as to where to ask a question and how to keep it comments on single topic raised- i'll keep it on track wink
thanks
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.207s Queries: 14 (0.203s) Memory: 0.6308 MB (Peak: 0.7061 MB) Data Comp: Zlib Server Time: 2025-09-22 22:29:39 UTC
Valid HTML 5 and Valid CSS
