Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (KEVINSKI, 68ironhead, 1 invisible), 103 guests, and 4 robots.
Topics128,274
Posts1,058,436
Members48,490
#872799 08/07/2012 4:53 AM
This week i am putting in the tailpipes on my 56 3100 with the 235. i have the Fenton headers and a 2-in, 2-out muffler so i am running a dual exhaust back. i am having the pipes custom bent, so any routing/shape is possible if it fits.
So - I am looking for ideas for where to have the pipes exit. Some possibilities are 1) at the rear with one in the stock location and one on the other side in a symmetrical position - this presents an interference challenge with the under-bed spare tire on the passenger side; 2) both pipes side-by-side in the stock location on the driver's side; 3) one on each side exiting behind the rear fenders; 4) one on each side exiting ahead of the rear fenders at the steps; 5) other?
Any ideas of what fits and looks good? Any pics? I'm putting stainless tips on the ends.
thanks!
tomctomc #872867 08/07/2012 11:27 AM
these are 3" Dynatechs but the concept works great(from Summit) easy removable and seals.
CLICK IT EXHAUST V-CLAMP
Dogs51Burb #873087 08/08/2012 7:44 AM
I put mine side by side rear exit.
pic
I like it except for them being visible between the bumper and the bed.
regards,
Leon
Leon #873097 08/08/2012 9:12 AM
Leon, thanks - looks great. i am leaning toward this idea as well. i might end them short of the bumper, tho.
The exhaust is going in on Friday 8/10. Any more ideas would be appreciated.
tomctomc #873148 08/08/2012 11:48 AM
I have one out the side before the rear tire. When I go dual I'll either do both out the same side at an angle or one out each side.
...I'm not using a rear bumper and it looked kinda funny hanging out way low.
BLUEMEANIE #873310 08/08/2012 10:44 PM
The Trucks! guys ran the pipes out through the running board.
classix pipes
regards,
Leon
Leon #873349 08/09/2012 3:40 AM
Thanks for the replies gentlemen. While i think that the "through the running board" look is cool - there is no way i am cutting up the sheetmetal for my pipes!
tomctomc #873539 08/09/2012 8:00 PM
You could also position them just below the running board if you like the side exit.
regards,
Leon
Leon #873805 08/10/2012 6:31 PM
Personally I like the stainless steel center mounted ones on the rear like my Camaro has. They are about 6" wide ea. I can post aphoto if you like as there are't a lot of them running around on the street.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
