5 members (UtahYork, BC59, KEVINSKI, dt235sd, 1 invisible), 94 guests, and 2 robots.
Topics128,211
Posts1,057,469
Members48,473
hey guys,
newbie kinda question, were do you get the parts to rebuild the front end on a 1949 chev 1.5 ton truck? (like factory new)the half ton stuff is everywhere...
thanks in advance
You'd be surprized what you can get at your local NAPA or big truck spring shop.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
mike thanks, i'll tomorrow smile
i forgot to ask, what is a big truck spring shop?
thanks agian
3B Offline
Hy dukedaddy, kingpin kit for models QJ, QK, RJ, RK, SJ, SK, TJ, and TK 1 1/2ton Napa p/n NCP2621161 $71.10, RockAuto Moog p/n 8207B $23.79. these kingpins are .921" in diameter by 5.125" long, hope that helps.
Duke,
Most big cities have spring and suspension repair shops that work on BIG trucks. They do springs, king pins and drive shafts etc., thay might be a source for you.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
3B Offline
Hy dukedaddy, firstly lets start with one thing at a time. This post was originally about front axle rebuild parts, if you now want to talk about engine/truck identification, please start another post about that. People will only see the front axle question when looking through the forums. About the information I posted, the two letter codes are truck model designations, these were used before the number series was introduced, they are all the models the kingpin repair kit fits, they are all 1 1/2 ton trucks I believe. Napa is a huge aftermarket parts supplier, and the p/n (part number) I posted is their identification number for the kingpin overhaul kit they stock. RockAuto is also an aftermarket parts supplier, and usually the cheapest supplier for most things, both are accessible on the internet. Hope that helps.
3B, yes- thank you that does help smile
And you are correct about starting another post... I was thinking more along the lines of a conversation that can flow from detailed topic to other items under the original umbrella of conversation. I will correct and will try to stay on topic. Thanks again I appreciate the feed back.
DD
guys i removed the post where i had asked about truck vin #s and truck ID. i did start a new post on that topic-
thanks 3B for guiding me as to where to ask a question and how to keep it comments on single topic raised- i'll keep it on track wink
thanks
