0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
#867624 07/18/2012 1:36 PM
Looking for some opinions and advice. I have a '57 3800 that I plan to restore. I'd like to upgrade the power plant to make it a little more usable for towing and hauling. The little 235 that's in it now purrs like a kitten but it's just a little short in the britches at highway speed. I have two engines currently available. One is a 283 with a 4 bbl carb removed from a '58 two ton truck. The SN indicates that it's an early 60's engine. The other option is a stock '80 model 292. I have a 4 bbl intake for it sitting on my shelf. I'll keep the standard granny low 4 speed tranny and I have upgraded the rear to 4.10 gears. The tires are R6-19.5. My goal is to have a truck that I can drive anywhere and do a little hauling and towing when needed. It would be nice to be able to trailer my 4000# tractor at 55 mph. Does anyone out there have any opinions about which engine would be the best fit? Should I look for something bigger like a 350? Any advice or opinions from those with experience will be appreciated.
Jeff
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Just saw an ad for a '79 400 sbc close by. I may take a look at it tomorrow. Would that be too much engine? Any problem fitting it into a TF?
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
no problem fitting any SBC in a TF truck, but 'bigger' isn't necessarily better, the 283 will do anything you ask of it, and last longer than a 350 .... I'd pass on the 400, but it's your truck and your money wink
292 all the way! It will out-torque the 283, and you won't have to downshift it every time you head uphill with a little load on. The 350 might get a little better gas mileage than the 292, but the 292 is designed to be a truck engine- - - -much better low end and midrange pulling power!
Another fan of the 292, but I'm not familiar with swapping one into a '57. They first were out in '63, where a small block, of course, was available in '57.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
He would need a V-8 bellhousing for the 57 since the 2nd.-generation sixes have a V-8 bellhousing bolt pattern, and a set of mid-engine mounts would need to be fabricated to the frame rails. A radiator upgrade would probably be a good idea as well, since the 292 will develop enough heat to stress a 235 radaitor somewhat.
if a stock rad can take a warmed over V8, it should handle a 292, and with a 4:10 rear and 4 speed there shouldn't be any torque lack with any engine .... I've pulled some good hils at moderate speed without down shifting with both my trucks [green 235, red 283, both 3.90 rears] loaded 1200-2000# without downshifting .... a good 283 will perform fine, and not require any modifications to install [other than a fan shroud or the original rad repositioning] if it comes with the correct bellhousing
The main advantage the 283 has for me is that I already own it. I also have the '58 Viking it came out of so I've got the bell housing, larger radiator, and fan shroud. I even have the 5 sp tranny if I want to go that route. The 292 I can get by buying the truck with a bad tranny for $600 and the 400 sbc can be bought for $450 or less and I can hear it run before it's removed from the truck. I would also have to come up with a flywheel for either the 292 or 400 since they're both in auto trucks. I would like to have the 292 and 400 for future use but I don't know if I want to lay out the $$ right now when I already have a good engine sitting in my shop. I need more time and more trucks to be truly happy.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
If the 283/5 speed setup has a 5th. gear overdrive, transplant the whole thing. The 292 wil bolt up to the same bellhousing the 283 uses, and I believe the 283 flywheel/clutch setup will also work with the 292 if you decide to go with the 6 cylinder option. One of the 5 speed setups uses a huge SAE type bellhousing adapter and a really big flywheel, clutch disc and pressure plate.
Unfortunately the 5 sp doesn't have OD. I would love it if it did. Still having 4 usable gears + granny wouldn't be bad either but it's a bigger animal (NP540GL) than the SM420. I've read on other sites where people have put them into 1/2 ton pickups so it's doable. Sure would like to have the GO (overdrive) model though.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Crusing in the Passing Lane
The GO's are really rare, I would use the 292, w/ the 5 speed, it is more useful, especially w/ a load, to be able to use 4th. on steep hills, rather than let the speed bleed off to 30 or so for 2nd on a 420. 9:1 propane pistons are available for 292's.
Your 540 might have the long input shaft, > 7", mix and match that bellhousing, flywheel, clutch, etc., to make it work.
I had an early Bronco, that I put a 540, Buick even fire 231 V6, 350 rear, very useful combination, hauling up to 14,000 GVW, that 5 speed made it work well.
Might look at slightly higher rear ratio depending on empty/loaded use.
I still might get the 292 but I went to look at the 400 sbc last night and ended up buying it for $400. It ran good with no noises or smoke. I was influenced a little by the fact that the guy selling it seemed like a nice kid and he's in a bit of a financial bind. I'll take a look at putting the 5 speed in when I have the truck disassembled. If it fits in ok I'll give it a try. I've got 4.10 rear gears now which are hard to find. Don't think I can go any higher without changing the rear axle. There were supposedly some 3.90's made but I've only heard of one person who had them in a junkyard and he wouldn't sell. All this planning makes me wish I had time to work on it. But it's 104 outside today so I'll probably wait 'til fall.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Someone mentioned GM 14 bolt FF axles accept Eaton brakes, etc., have lots of ratios, cheap.
I was really leaning toward the 292 but the deal fell through. After driving 2 1/2 hrs to look at a truck with a "good running 292" I found a truck with a 250 that hasn't run in years. I couldn't convince the owner that he's got a 250, he's certain that the 4.1L on the emissions label means 292 cu in. I did offer to buy the exhaust manifold because it's a factory dual exhaust, which I haven't seen before, but he wouldn't deal on it. He'll probably end up selling the truck for scrap. That's okay, I've got enough toys to play with for awhile.
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
I think you can't go wrong with the 400 or the 283. Plus it'll sound great with some long, mellow glass packs. There's nothing sweeter than rumbley mellow packs with a manual trans.
I did find a 292 pretty cheap but I have a feeling it needs to be rebuilt. It's already pulled and been sitting in a shed for a couple of years so I'm taking the owner's word that it's a good engine. I'll probably look at it as a long term project to overhaul for future use. Both the 283 and 400 can be used with just a little clean up and orange paint. I don't think any of these 3 choices will run very far on a gallon of gas so that's not a factor. I'm leaning toward the 400 because it has the AC compressor and power steering pump with it. I've learned from experience that I'll drive a truck more often if it at least has air conditioning. There doesn't seem to be a commonly used method for adding power steering to these 3800's so I'll have to do more research on that part. It's fun to plan for this stuff even if I don't have time right now to work on it. Thanks for all the advice.
Jeff
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
I've put a 292 in my 53 3800 , used the early
V8 bell housing and a A833 trans with the
over drive 4 th gear , with the 19.5 wheels
and a set of 4.10 gears it's a very nice driver
292 is the right engine, The 283 has a 3 inch stroke,And has no torque,And you need torque if you want to move, tow or carry heavy loads, The 292 stroke is 4.125,The End.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
283 has a bore of 3.875 and a stroke of 3.00,A 327 has a 4. bore and a stroke of 3.250,350 has a 4. bore and a 3.500 stroke,A 400 has a 4.125 bore and a 3.750 stoke, And a 292 has a bore of 3.875 and a stoke of 4.125, If you want HP go with big bores, If you want torque go with the longest stoke. HP is normally higher RPM and Torque is lower RPM.
I was able to get my paws on a recently rebuilt 292 so it looks like it's getting first shot. I'll add an offy intake and small 4 bbl and possibly a few other goodies to help it out. The 400 sbc was running and didn't smoke but it has over 100k on it so I would prefer to go through it before putting it into a truck. The 292 will get me going sooner. If it doesn't have enough getty up to satisfy me I'll look at rebuilding the 400 for a long term fix. Even though the 400 has about 10% shorter stroke it also has 33% more cylinders and 37% more cubes which results in 15% more torque at about the same rpms as the 292. Both have their torque peak at around 2000 - 2200 rpm's which is about where I need it with my gearing. I really like the simplicity of the straight 6's so hopefully the 292 will pan out. Thanks again for all the advice.
Jeff
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
Moderated by  Dusty53
