0 members (),
46
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | I am contemplating putting power steering in my 57'. Cpp is offering a kit for this truck. Just wondering what other people have done. I still have the I-beam suspension. The only change is disc brakes.
Roy | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | There are several conversion kits out there. One bolts on and uses a control valve that replaces the drag link and a ram that bolts on to the tie rod. It is similar to the factory system and uses the stock steering gear. I had one and didn't care for it. Another system uses a 70/80's Saganaw gear box. Be carefull not to get too fast of a ratio box. It will require modification to the steering column. Some replace the entire column with something newer. I used the Toyota kit. I installed it over 10 years ago and it works great. They are getting a little scarce and pricy as well. It will also require modification to the column. Fred
