7 members (Brian Moore, tclederman, Lightholder's Dad, jupitor, treegrower, GMCJammer51, J Lucas), 223 guests, and 1 robot.
Topics128,080
Posts1,055,952
Members48,430
#868198 07/20/2012 9:07 PM
Big Bolt Forum Co-moderator
I was doing some searching the internet looking at info on spray painting and found an article that mentioned Gibbs Penetrating Oil. The guy was working on a project and wasn't going to be paining it right away, but was down to bare metal. He used something called Gibbs to keep the rust away. He stated in the article that you need to prep the metal when ready to paint, but that the oil did not affect the paint, since there could be some in a seam or whatever. Anyone here ever used Gibbs or know where to find it?
1948 Chevy 2-Ton
Super55 #868201 07/20/2012 9:14 PM
www.getgibbs.com
Im on my 4th can,,it works where others dont.
delux54panel #868208 07/20/2012 9:47 PM
Only over the internet? Has anyone had experience with painting over it?
1948 Chevy 2-Ton
Super55 #868218 07/20/2012 10:19 PM
yes, it's mostly an online thing but some shops have it, especially motorcycle shops and gun shops .... it is good stuff and seems to act like a rust converter, I got a couple cans and have used it as a rust preventer in hidden areas as well as removing rust from chrome - haven't painted over it but I don't see why it wouldn't work after normal prep steps .... there's someone Lower Mainland that sells it, but I've misplaced the name right now, you might find out at the Gibbs site
Flxible #868413 07/21/2012 9:46 PM
I have used it and it seems to be good stuff. I bought it on line from the manufacturer.
1957 Chevrolet 1/2-ton Stepside LB in the Gallery
My Photobucket shots
The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873)
Alan's 57 #868420 07/21/2012 10:05 PM
I used Gibbs to protect my step side bed after I stripped it down to bare metal.
It protected the metal for 3 months, then I simply wiped it down with xylene before priming the metal.
I still have some Gibbs left over and use it just as you would use WD-40.
Hot Rod John #868461 07/22/2012 1:36 AM
Dang, sounds good. I wonder why they don't sell it at your local neighborhood parts store. Guess I'll go online. I saw they have a Canadian page too.
1948 Chevy 2-Ton
Super55 #868750 07/23/2012 9:20 AM
If you're looking to protect metal prior to painting there are probably better products that are actually an aid to painting and not necessary to remove like you would an oil
Picklex is one http://www.picklex20.com/
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #868948 07/23/2012 9:40 PM
Grigg
Picklex is not compatible with some primers. It's NOT compatible with etch primer, for sure. I used it on my bed pieces before putting them into storage.
Other Bolters had cautioned me against it because of known incompatibility issues, yet I know that some Epoxy primers will work with it.
I'd say you should apply epoxy primer to your bare metal ASAP. If, like me, you can't do that, then Picklex is one of many options that will work but I'd first make sure it will not cause adhesion problems with whatever primer you plan to use. Apparently, epoxy primer is fine as long as it does not contain any acid.
I have the MSDS for Picklex if anyone cares to read it. Just send me a PM.
You can find out a lot more about Picklex by visiting this forum page.
Lugnutz #869069 07/24/2012 10:49 AM
Good to know!
I didn't realize it only works well under some primer and not all. A little research prior to using it with any paint system is definitely in order.
Grigg
---All pictures---
Grigg #871141 08/01/2012 2:06 AM
Many years ago auto supply peddlers who called on us had Gibbs. It was good stuff. I don't remember how many years it has been since guys peddled stuff like Gibbs and Bowes Patches etc. I Didn't realize it was still available online.
Super55 #873379 08/09/2012 9:37 AM
I have used it and like it, but everyone has their own preference for penetrating or other lubricants.
I bought mine from http://www.gibbsbrand.biz/index2.html When I bought, they had a policy of price matching and Billy Grubbs was pleasant to deal with. I will need to get more soon.
Moderated by  MNSmith
