1 members (WingWright),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | This week i am putting in the tailpipes on my 56 3100 with the 235. i have the Fenton headers and a 2-in, 2-out muffler so i am running a dual exhaust back. i am having the pipes custom bent, so any routing/shape is possible if it fits.
So - I am looking for ideas for where to have the pipes exit. Some possibilities are 1) at the rear with one in the stock location and one on the other side in a symmetrical position - this presents an interference challenge with the under-bed spare tire on the passenger side; 2) both pipes side-by-side in the stock location on the driver's side; 3) one on each side exiting behind the rear fenders; 4) one on each side exiting ahead of the rear fenders at the steps; 5) other?
Any ideas of what fits and looks good? Any pics? I'm putting stainless tips on the ends.
thanks! | | | | | Joined: Apr 2008 Posts: 99 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 99 | these are 3" Dynatechs but the concept works great(from Summit) easy removable and seals. CLICK IT EXHAUST V-CLAMP
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | I put mine side by side rear exit. pic I like it except for them being visible between the bumper and the bed. regards, Leon | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | Leon, thanks - looks great. i am leaning toward this idea as well. i might end them short of the bumper, tho.
The exhaust is going in on Friday 8/10. Any more ideas would be appreciated. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I have one out the side before the rear tire. When I go dual I'll either do both out the same side at an angle or one out each side. ...I'm not using a rear bumper and it looked kinda funny hanging out way low. | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | The Trucks! guys ran the pipes out through the running board. classix pipesregards, Leon | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | Thanks for the replies gentlemen. While i think that the "through the running board" look is cool - there is no way i am cutting up the sheetmetal for my pipes! | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | You could also position them just below the running board if you like the side exit.
regards, Leon | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Personally I like the stainless steel center mounted ones on the rear like my Camaro has. They are about 6" wide ea. I can post aphoto if you like as there are't a lot of them running around on the street. | | |
