0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#87299 02/15/2002 4:15 AM
Junior Member
Junior Member
My 54 was already converted to 12 volt by the previous owner. The heater has not worked since I got it (nothing from the motor) can I hook it up to the battery to test it (without regulator and switch) or will that kill it.
Just wondering?
Dave
54 1ton
#87300 02/15/2002 2:38 PM
Good question Crabby....I'd like to know the same as I'm trying to find a heater for my 47'and then I'll be needing to connect to a 12 volt system also.. So I'll be watching the Forum for the advice that will surely follow... smile
49' Chev, 3808 platform
#87301 02/15/2002 4:02 PM
When I recently did my conversion, I put a heavy duty resistor in front of my heater switch, though it act's like no resistor is present. Now the lowest setting on my switch sounds like what my highest setting use to be like when it was 6v. If I switch to high now called "GO-BABY-GO" (from Gone in 60 seconds), I'm afraid I'm going to burn out the motor. I might try another resistor.
Craig
#87302 02/15/2002 4:37 PM
thadley, there is someone on the swapmeet with numerous 40s era heaters.
54 3100 with 235
62 flatbed dump C60 with 261
#87303 02/15/2002 4:57 PM
You made two resistors in line to the heater to keep it from running too fast.
#87304 02/15/2002 5:00 PM
It is ok to hook up the heater motor to a battery to see if it will work. If you run it for a couple of minutes you should be able to see if it is going to work or roll over and play dead. If it works i now have the heater motor voltage reducers available so you can keep the stock heater blower motor and switch. Let me know....Randy grin grin grin
#87305 02/17/2002 4:13 AM
I used a motor from Advance Auto. It was a universal 12volt and had the two lugs on front to mount like orig did, same size shaft too. Think I had to oval mount holes some, used old fan blade after finally getting out the old set-screw and it can be hooked up to turn either way, depending on what wire power goes to.
Might want to check your heater box for mouse nestings, Most old trucks I've dragged home have 10lbs of mouse nest in them and stink like Pee real bad. Even wasps make mud nests in them and freeze everything up. A little oil on shaft bearings, spin it to free up and away you go! I've used 12 volt on 6 motor to get it started after it wouldn't move on 6. Once it "broke in" on 12, it worked again on 6. grin
G.L. Grumpy's
Old Iron Ranch
Huntington, IN 46750
MM R tractor, Speedex
and Power King tractors
