3 members (Gdads51, Hotrod Lincoln, 1 invisible), 115 guests, and 0 robots.
Topics128,039
Posts1,055,591
#872831 08/07/2012 9:17 AM
Hi all. I have another quick question. Is this bondo?? I'm almost afraid to start sanding here. eek
Husker #872848 08/07/2012 10:33 AM
That looks like rust to me... Underneath the bondo. A good example why some folks now choose to apply epoxy primer befor fillers.
Give me ambiguity
or give me something else
Husker #872850 08/07/2012 10:34 AM
Maybe a little bondo there but that is not what I would worry about. Check that rust to see if you have solid metal underneath. A test with a sharp pick is in order to see if you have any rust through.
Ed Fallon
In seemlingily endless process of restoring a stock 1953 chev 3100 pickup.
Ed's_53 #872862 08/07/2012 11:14 AM
Ex Hall Monitor
Ex Hall Monitor
That is body plastic filler (Bondo is a brand name) that lost adhesion and allowed the raw metal underneath to rust. Don't be afraid to sand because you'll need to remove all of the failed filler and rust before you can proceed anyway.
Tiny #872901 08/07/2012 1:46 PM
agreed- filler over rusty metal-
Might not have been rusty when the filler was applied but the filler cracked and let moisture in- and there you see the result...better to find it now and address it then to just have primed and painted ofer the work and see it ruined a little bit down the road.
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
