4 members (Woodcmiami, MRMEROTH11, Gray_Ghost, 1 invisible), 129 guests, and 2 robots.
Topics128,121
Posts1,056,328
Members48,439
I ran across a 1984 P35 step van today. It has independant front suspension with power disc brakes and power steering. It has 10 hole 19.5 tubeless wheels too. Is the 35 a 1 1/2 ton ?
It would be fun if my '52 6400 cab and front clip would mount up to the chassis instead of moving all the running gear to the '52.
1952 Chevrolet 6400 flat bed
Riding in the Passing Lane
It is rated as a heavy 1 ton. I believe the GVW is 12000 lbs.
1972 Chevy c10 Cheyenne Super
Crusing in the Passing Lane
You can also find 22.5 tubeless wheels for the P3500.
You can find the GVWR plate on the vehicle somewhere around the drivers door area.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
