3 members (Nick in Manitou, Hotrod Lincoln, Hanks custodian), 84 guests, and 2 robots.
Topics128,035
Posts1,055,559
#871853 08/03/2012 1:37 PM
My 1/2 ton '37 truck (216 cid) has a coil mounted above the distributor. On the bottom of the coil is the lead to the center of the dizzy. However, on the top of the coil is a heavy shielded cable runnig to what loooks like a cap on the coil. Is this correct? How do I connect a new coil?
Thanks in advance,
CAB
That arrangement is to make it theft proof and the power to the coil goes through the steel cable which is attached to the ignition switch. I have this on my 38 and I will not be using it. You can hook up a new coil in the normal way. If you want to replace the old coil with a new similar one, there is a thread somewhere on this board that tells how to remove the cap.
1951 1 Ton Completed
truckernix #872588 08/06/2012 1:23 PM
I've searched through the archives for the post on removeing the cap on the old coil but with no luck. Can someone tell me where the post is, or better yet, tell me how to remove this old cap on the coil. It would be appreciated.
CAB
Christopher,
I have sent you an Email with a diagram of how to unlock the cap.
Fred
truckernix #872618 08/06/2012 3:42 PM
I was able to send the diagram of the coil lock but I can't find the instructions of where to stick the blade under the cap. Does anyone have those instructions?
truckernix #873306 08/08/2012 10:40 PM
Fred,
I would really appreciate it if you would send me a copy of how to unlock the coil cap lock you mentioned in your post above.
Harold
Harold
Harold46 #873351 08/09/2012 4:50 AM
Harold,
I have sent the diagram in an Email.
Fred
