| | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87194 04/26/2004 1:41 AM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I have a black, brown and green wire from the headlight does anyone know what wires belong where? This is a 1953 GMC with a new Chevy Duty wiring harness. I'm sure one is high beam, one for low beam, and a ground maybe? | | |
#87195 04/27/2004 8:14 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Hi, low and ground. I believe the black is ground.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#87196 04/27/2004 10:19 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | I received an e-mail from Chevy Duty and they gave me the following information: Highbeam green, Lowbeam brown, and black a ground. | | |
#87197 04/27/2004 10:20 PM | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | Did you get the numbered list from CD that told what each wire was, I didn't when I got my harness so they faxed it to me. If not I can look it up for you when I get home tonite as I still have all that stuff. Also you might find this helpful. it's the wireing diagram that I used when installing my harness. On my diagram black is ground, Green hooks to Black #16 at the terminal block and Brown hooks to Green #15 at the terminal block. I'm a visual person so I always have to have a current wiring diagram in my truck in case I have trouble. MONGO | | |
#87198 04/28/2004 2:23 PM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | KCMONGO, It would be great if you can send me a copy of the wiring diagram. I appreciate the above info, it will help tremendously!!!!!  | | |
#87199 04/28/2004 3:40 PM | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | Here you go.. 47-53Wire.pdf Good luck let us know how it turns out. Mongo | | |
#87200 04/29/2004 1:07 AM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | KCMONGO,
The 47-53 Wire.pdf link doesn't work. Can you resend it?
Thanks | | |
#87201 04/29/2004 1:19 AM | Joined: Sep 2002 Posts: 115 Member | | Member Joined: Sep 2002 Posts: 115 | Hmmm....
Works fine here.
Joe | | |
#87202 04/29/2004 2:28 AM | Joined: Jul 2000 Posts: 619 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 619 | It's a PDF file, do you have Adobe Acrobat reader intalled on your machine? MONGO | | |
#87203 04/29/2004 3:45 AM | Joined: Oct 2000 Posts: 244 'Bolter | | 'Bolter Joined: Oct 2000 Posts: 244 | KCMONGO, It works now, the computer must have had a hiccup. It looks great!!!! This will make my wiring job easier. Thanks  | | |
