2 members (baldeagle, dunfire), 86 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#87194 04/26/2004 1:41 AM
I have a black, brown and green wire from the headlight does anyone know what wires belong where? This is a 1953 GMC with a new Chevy Duty wiring harness. I'm sure one is high beam, one for low beam, and a ground maybe?
#87195 04/27/2004 8:14 PM
Hi, low and ground. I believe the black is ground.
#87196 04/27/2004 10:19 PM
I received an e-mail from Chevy Duty and they gave me the following information: Highbeam green, Lowbeam brown, and black a ground.
#87197 04/27/2004 10:20 PM
"MONGO"
"MONGO"
Did you get the numbered list from CD that told what each wire was, I didn't when I got my harness so they faxed it to me. If not I can look it up for you when I get home tonite as I still have all that stuff.
Also you might find this helpful. it's the wireing diagram that I used when installing my harness.
On my diagram black is ground, Green hooks to Black #16 at the terminal block and Brown hooks to Green #15 at the terminal block.
I'm a visual person so I always have to have a current wiring diagram in my truck in case I have trouble.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
#87198 04/28/2004 2:23 PM
KCMONGO,
It would be great if you can send me a copy of the wiring diagram. I appreciate the above info, it will help tremendously!!!!! grin
#87199 04/28/2004 3:40 PM
"MONGO"
"MONGO"
Here you go..
47-53Wire.pdf
Good luck let us know how it turns out.
Mongo
Mongo's Garage
#87200 04/29/2004 1:07 AM
KCMONGO,
The 47-53 Wire.pdf link doesn't work. Can you resend it?
#87201 04/29/2004 1:19 AM
Hmmm....
Works fine here.
Joe
#87202 04/29/2004 2:28 AM
"MONGO"
"MONGO"
It's a PDF file, do you have Adobe Acrobat reader intalled on your machine?
MONGO
Mongo's Garage
#87203 04/29/2004 3:45 AM
KCMONGO,
It works now, the computer must have had a hiccup. It looks great!!!! This will make my wiring job easier.
Thanks grin grin grin
