4 members (Gdads51, 51sub, MickeyP, Chip O), 68 guests, and 2 robots.
Topics128,041
Posts1,055,593
#871612 08/02/2012 6:31 PM
The 235 in our new truck(1948) has a lot of black sludge in the block. I've pulled the drain cock from the block and tried to back flush from there. No luck. I made a plate to go in place of the thermostat housing and tried to flush that direction, without luck.
I've got a new radiator to put in, but need to get the sludge out of the block before I install the radiator.
Does anyone have any ideas short of hot tanking the block?
I'd like to get it running and check it out before tearing into the engine.
Power washer, car wash, stiff wire, screw driver, lots of options with little work involved. Its mostly just bits of crude jammed together, so once you get some of it loose, the rest will follow. Power washer works best back flushing.
Joe
Joe H #871682 08/02/2012 10:25 PM
On the block drain work a pc. of stiff wire in there tell some water starts flowing,than like Joe said it will start coming out easyer.Power washer is the tool for this job.
Pete
Is it a 1948 235 or a 1955-2nd or newer 235?
Thanks for the suggestions. I finally hooked up my air compressor to the block drain and let it sit with pressure on. I pulled the water pump so I could get back along the cylinders and finally started to hear some bubbling from the back. I tapped around the drain with a small hammer and it finally broke loose. I'm going to hook my garden hose up to the drain now and back flush it good.
57210 #871691 08/02/2012 10:48 PM
Oh I forgot, it's a 55 model 235
