0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#871645 08/02/2012 8:19 PM
54 gmc converted to 12v. reading 24v at battery. back of the fuel gauge reads 24.8 and 11.4 at sender. what could be going on?
you're reading the wrong scale on the meter? you've got 2 batteries? with a 12V battery it'd be pretty hard to get 24V unless you've got an alternator on steroids
Flxible #871811 08/03/2012 9:24 AM
yep wrong scale. well now the back of the fuel gauge reads 11.8 and the top of the fuel tank sender reads 1.8. the gauge is brand new as is the fuel sender. grounding the sender the gauge sweeps. grounds are on bare metal. stumped. any ideas??
54GCPGMC #871816 08/03/2012 10:10 AM
voltage at the sender is irrelevant, the sender supplies the ground for the gauge and you're reading thru it's resistance .... if "odd" readings are the only problem, quit reading wink does the gauge work properly? [grounding it should make it move]
Flxible #871819 08/03/2012 10:19 AM
the gauge moves when the sender is disconnected. yes.
54GCPGMC #871836 08/03/2012 11:43 AM
i hooked up a wire directly from the battery to the gauge and clean grounds on both sender and gauge. it is a 12v vdo gauge. the sender is brand new.
With the sender grounded you should see an empty reading. With the sender disconnected you should see a full reading. Moving the sender through it's range, I would expect to see it go from 0 to 30 ohms, or close to it.
1951 1 Ton Completed
Are the sender and gauge matched? A stock gauge uses a 0-30 ohm sender. The VDO gauge may or may not.
Cletis #871893 08/03/2012 4:38 PM
yep got off the phone with vdo. they are sending me the matched fuel sender. will get it next week and see what happens.
Flxible #871903 08/03/2012 5:14 PM
Red that is the best explanation I have ever heard for the fuel gauge/sending unit
1938 Gmc 1/2 ton
So got the part from VDO today installed it and popped right up on the gauge. right sender right reading. thanks
