1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#87148 06/02/2003 3:15 AM
What is the correct way to wire a tach ?I have had a few different tachs and it seems they don't last long.Thank you for any help!
#87149 06/02/2003 5:49 AM
How many wires and what colors do you have?
Mine goes like this :
Black wire = ground
White wire = headlight dimmer switch
Red = Voltage Terminal
Green = distributor
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#87150 06/03/2003 5:54 AM
What does a dimmer switch have to do with a tachometer? Are you using this connection for lighting?
#87151 06/03/2003 8:00 AM
I'm guessing that the white wire is for the tach illumination. When I have installed aftermarket gauges, I always hook the light wire that goes to the dash lights - that way the brightness is controlled for the new gauges, just like the stock ones.
1954 GMC De Luxe COE
#87152 06/03/2003 4:52 PM
What he said.
The dimmer switch (I'm referring to the headlight dimmer switch) controls the brightness of the bulb in the tach and all other gauges.
PS - re: your sig-line, GMCpanel -- I don't think God intended there to be religions! Just faith.
grin
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#87153 06/04/2003 8:44 PM
thanks guys!
