9 members (farmallb, moparguy, Opelika Tom, mk72, Otto Skorzeny, Oswald, Hush, RoadsScholar, 1 invisible), 181 guests, and 1 robot.
Topics128,089
Posts1,055,988
Members48,430
#87143 03/29/2005 2:50 AM
Junior Member
Junior Member
I have a 41 1/2 ton converted to 12 volt with the new voltage converter. with the ignition turned on the fuel gae pegs to full. Before I start pulling everything apart am I missing something
41 1/2 ton
don't force it get a bigger hammer
#87144 03/29/2005 4:05 AM
Red dot, center of chest ...
Yes, you are. You can't run a 6 volt gauge on 12 volts. You need to do one of two things. Either buy a reducer to get the voltage back to 6 volts or change the fuel tank sending unit to a 12 volt unit.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
#87145 03/29/2005 4:48 AM
Junior Member
Junior Member
I do have the reducer on to convert back to 6 volts
41 1/2 ton
#87146 03/29/2005 5:01 AM
Bad ground wire or the wire from sending unit to guage open. Works opposite from what you would expect. Went thru same thing when I changed wiring harness on mine.
#87147 03/29/2005 6:08 AM
Greg's right. Your problem is most likely a bad ground. I had to run a ground wire from the frame to one of the screws that holds the fuel tank sending unit in place to get mine to work right.
Paul Schmehl CI 6
geek@stovebolt.com
