| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87115 12/16/2001 10:40 PM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | I have a VDO electric fuel gauge in my 59 Apache, It was working fine when it went to the body shop, but since it has come back the guage needle goes all the way to the right when i fire up the truck. The guys at the body shop had to diconnect it from the sender to move the bed back. It is hooked back up right but it still goes pinned right. Is it the sender unit or the gauge? :confused:
1972 Chevy Cheyyenne, 1959 Chevy Apache
#87116 12/17/2001 3:04 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | How's your ground wire connection from the sender unit hold down screw to the frame? Did they reconnect that wire?
Joe
#87117 12/17/2001 10:24 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Yes, what chevy-1 said,,,, did you get the wire reconnected from the ground screw(holding the sender in the tank) to the frame for grounding?
#87118 12/17/2001 11:44 AM | Joined: Sep 2001 Posts: 23 Member | | Member Joined: Sep 2001 Posts: 23 | Let me crawl under and check.............
