Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (Peggy M, TUTS 59, Waveski, 55shaker, Joe W, RBs36), 526 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
#87105 07/20/2003 1:21 PM
Junior Member
Junior Member
I have a 1949 chevy 6400 that has been sitting for a while. When I hook up the battery to turn the engine over, the steel tube for the oil pressure sending unit gets very hot. Could the engine be trying to ground through this tube? I know I will have to rewire it, but I want to hear it run. Any help will be appreciated.
#87106 07/20/2003 1:59 PM
har to say, without seeing the set up. take a jumpercable from battery negative to engine block
and also to cab body.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
#87107 07/20/2003 4:10 PM
Big Bolt Shop Curmudgeon
Something is amiss with electricity getting into the metal of the tube causing the tube to glow in the dark.
Check for frayed wires contacting the tube. The suggestion about checking for a good cab ground is appropriate. Somehow, the dash lights and such in the cab may be returning to ground through the tube.
The funny part about electrons is that they will find a path, any path, even ones they are not supposed to use, and in the absence of a path, they will leap across gaps. Of course, in the case of spark plugs, this is good.
I apologize for sounding so insultingly simplistic. I don't mean to be talking down to anyone.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy
"Ol Blue", or "THE BIG 'UN"
#87108 07/20/2003 8:45 PM
Buttermilk, like Fritz says, try another ground. I'd install an additional ground from the battery to the engine block, leaving the old one in place. Then check to see if it gets hot with that ground in place. Mike
#87109 07/24/2003 2:27 AM
Junior Member
Junior Member
Fellers, I really appreciate your response. I will try them this weekend. Thanks again. Steve Ramsey
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.180s Queries: 13 (0.042s) Memory: 0.6086 MB (Peak: 0.6539 MB) Data Comp: Zlib Server Time: 2025-09-22 17:00:11 UTC
Valid HTML 5 and Valid CSS
