Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (2-Ton, FAST55, Otto Skorzeny, rfs56trk, 1 invisible), 125 guests, and 5 robots.
Topics128,277
Posts1,058,441
Members48,490
#870905 07/31/2012 1:15 PM
I am rebuilding the Rochester carb for my truck and the instructions say "the pump piston cup must be coated with a light film of lubricating oil then flared before installation." How do I flare this? Thanks!
1954 Chevy 3100. Original 235 and Hydramatic
www.cardomain.com/ride/2344117
i just run my finger aound the inside of the cup. i flare it out wider then the cylinder, then carfuly seet the cup/piston into the cylinder.
What do you flare with?
Riding in the Passing Lane
If it is a leather cup you need to soak it in oil for a while. A rubber cup you can put a little oil or gtrease on it & use it.
1972 Chevy c10 Cheyenne Super
Ok perfect, thanks!
i flare it with my finger. i've only seen the leather cup version. they are usualy a bit dry and need to be oiled.
