6 members (MRMEROTH11, klhansen, Eisenholtz, TexasA&M48Truck, Wickedbass, Gdads51), 57 guests, and 2 robots.
Topics128,066
Posts1,055,875
Members48,428
#87073 09/25/2004 12:26 AM
What is the most likely problem with the gas gauge? After being stuck on empty, I VOM tested the sender unit which read about 18 ohms and checked the guage connections and it suddenly read 1/2 tank. Sounded right based on the resistance, plus what I thought was in the tank. But the guage did not go to empty when the key was turned off, but then again that's a GM feature. Here's the deal, I ran out of gas (thankfully 1 blk from home). Right before that happened, the guage went to 3/4, truck died then guage went back to 1/2 tank. What's happening here?
#87074 09/27/2004 9:03 PM
If your gas gauge doesn't drop to empty with the ignition off, maybe it doesn't run through the ignition switch. Check to see if there is +12V at the guage with the ignition off. It may be easier to just disconnect the battery - does the guage drop to zero?
Gord
1954 1/2 ton 235 4 speed
#87075 09/28/2004 1:26 PM
I just recently replaced my sending unit and had difficulty getting the gauge to work. I can't remember if I had the same problem but I did get it resolved for the most part by grounding the base plate of the sending unit to the chassis. Actually, I ran a wire from one of the screws that fastens the sending unit. Then ran it to the chassis. Gauge doesn't read quite right but I think the gauge is the rest of the problem.
