3 members (Wheelie, 1955 1 Series, Otto Skorzeny), 40 guests, and 6 robots.
Topics128,012
Posts1,055,315
Members48,419
#869879 07/27/2012 2:17 PM
Does anyone know how long a 1963 truck bed is? I also need to know how far from the front of the bed the middle of the wheels are. I am planning on building my 1963 c60 into a real big truck so I am trying to figure out how much frame I need to take out. Thanks
hardy541 #869880 07/27/2012 2:24 PM
aside from a shop manual, you need this as a permanent reference:
http://www.gmheritagecenter.com/gm-heritage-archive/docs/Chevrolet-Trucks/1963-Chevrolet-Truck.pdf
Flxible #869887 07/27/2012 2:57 PM
The link to the page that you sent me did not work.
hardy541 #869892 07/27/2012 3:24 PM
Bill's link works fine. You have to wait a while for it to load, because it is a multi-megabyte PDF file.
tclederman #870143 07/28/2012 3:29 PM
Thanks! that gave me the bed length, but i still did not see how far the frame extends from the back of the cab, or where the wheel is?
hardy541 #870149 07/28/2012 3:55 PM
isn't there a wheelbase spec in there? isn't there enough dimensions given for the various models that a little math can sort it out? have you thought how a bed designed for a drop center frame, will fit on a straight channel frame? do you have a bed to use or are you planning to cut up the frame and hope the bed you find later will fit?
Flxible #870151 07/28/2012 4:04 PM
The wheelbase spec wont work because of the difference in the nose. I am building a subframe to mount the bed on
Yes I have done the math and figured out my bed length and everything, but no where could I find how far back the wheels are mounted. I think the wheel center should be exactly halfway back the bed but would like somebody to confirm that. Thanks
hardy541 #870232 07/28/2012 10:56 PM
Are you putting a pickup bed on your bigbolt? If so how long is the bed (6-1/2', 8' or 9')?
I wouldn't cut anything before I had the bed in hand. If you have the bed, it's just a mater of dry fitting the bed on top of your frame until it looks centered over your axle and tires. Then mark it up and start cutting.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #870244 07/28/2012 11:42 PM
it is an 8' bed.I will dry fit it but any idea how much bed should hang over the end of the frame?
hardy541 #870245 07/28/2012 11:53 PM
Stand the bed up and measure it...I think it's about 48".
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Mike B #870642 07/30/2012 1:59 PM
I understand this is a C60? Correct?
Assuming it is the dimenbsionb you want is called the CA (cab-to-axle) and for various bodies is can be different but an 8' body (or bed as you refer to it) is probably a dump body. That uses a 60" CA. That is the shortest CA that was available and still is for a Ford or Ram 350-5500. If it is for a platform body it maybe 9'-10' long. Just depends on the particular application. In 63' a 72", 84", 102", 114" and 120" were also available and probably 138" and maybe even 150". So tell us what the body is and I can steer you correctly.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #870660 07/30/2012 3:38 PM
Dave, he's wanting to put a 60's longbed pickup box on his big bolt
Mike B #870680 07/30/2012 4:52 PM
Long WB pickup bodies are made for a 56"CA.
I re-read his question and still didn't see anything about a P/U body.
Dave
53moneypit #870705 07/30/2012 7:32 PM
did you read his responses above and other post that I linked? seems clear enough he's trying to turn a 1.5T into a "big" pickup
