| | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#87043 12/13/2001 9:13 AM | Joined: May 2001 Posts: 36 Member | | Member Joined: May 2001 Posts: 36 | Whats the biggest 12 volt Chevy generator, (amps that is) that can be readily bolted into an Advance Design truck?
I know that the stock 6 volt A-D generators were about 40 amps; and regulated at about 36 amps. And regarding pulley size, the drive ratio of engine RPM to generator spin was 1.83 (2400rpm generator to 1300rpm engine). {I mention this cause the ol'tractor restoration guys warned me about swappin' generators with different pulley sizes, seems it really screws up the cut-in-out voltages!}
But I was just pondering a switch to 12 volt and thought I remembered a rumor that some late 1950's early 60's BIG Task Force etc Chevy trucks (2 ton plus)MAY have approached 50+ amps?
If there is a 50+ amp Chevy generator, and If anybody knows the specific model please let me know so I can price it out.
Finally, I know the alternator swap is the most efficent way to go, but I was just wondering/diddling about big old generators.
[ 12-13-2001: Message edited by: lil' johnny ] | | |
#87044 12/13/2001 1:10 PM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | one question is ---whatcha gonna do with all them amps? do ya need 'em? at any rate, a good electrical shop can rebuild the gen. and install bigger stator windings--hench--more amps. for a more h.d. regulator, leece-neville makes one that can handle 130 amps o.k. (feel yer back pocket getting lighter?) anyhow, old g.m. generators were used in starter packs years ago--plenty of poop for starting cars with dead batteries.  | | |
#87045 12/13/2001 8:29 PM | Joined: May 2001 Posts: 36 Member | | Member Joined: May 2001 Posts: 36 | koolkar, Can the re-builder use the old 6 volt generator housing and insert the bigger amp coils? Or do I need to get a 12volt junk yard generator?
What I am going to do with all the amps. Well... that kinda falls into the realm of "whatta my gonna' do with a 50 year old, 8 foot tall, 2-ton truck".
[ 12-14-2001: Message edited by: lil' johnny ] | | |
#87046 12/13/2001 11:48 PM | Joined: May 2001 Posts: 477 Shop Shark | | Shop Shark Joined: May 2001 Posts: 477 | i like the pic--tis a thing of beauty---and one hell of alot of work!! o.k., down to work, if yer gonna keep the 6v system the stock gen is fine--as wel as the standard capacity 12v---if all yer doin' is what you say. i THINK the electrical shop can rebuild the 6v gen to 12 volts--but don't see the need for mongonmous amperage in the application you described. best advise i can give is go as close to stock specs. as possible---why fry batteries before their time? 50 or so amps. should do all you want in my opinion, especially since you ain't got a/c power windows etc. and while yer at the shop, inquire about 12v blower motor--might save you some pain later. hey--how about a picture of this monster? i REALLY enjoy checking out other guys stuff! hope i helped some dave  | | |
