3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
Can anyone tell me where the bed to frame ground is
on a '58 Chev Apache half ton? After 54 years it all
looks to be one color underneath.
Mike
there wasn't one from the factory, if all the bed mount hardware is clean and tight there will be a ground thru that, but if you're having problems with the lights, what most folks do is just add a wire from the rear cross sill [which is welded to the bedsides] to the frame .... you might also want to clean the factory attachments from the battery to cab and engine to cab
Hi,
Unfamiliar with rear cross sill?
Mike
there's a number of channel pieces supporting the floor from side to side, they're called cross sills, the rear most one, where the boards end and below where the tail lights mount to the stake pocket, is welded to the bed sides - it's also bolted to the frame
Any good woven ground connected from the frame to the bed will do. FYI grounds are like money, you can never have too many.
~Jim
