3 members (Guitplayer, Charles in CA, 1 invisible), 65 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#870331 07/29/2012 11:26 AM
Hello friends, I finally got the rearend in my 49' truck. I've got to get the driveshaft made and do a test drive on it to see how the 3.90's work. I'm still going to try and find some 3.55's, or something in that range. Be glad when this is over and I can drive. On the year model of the rear end I'm still looking, it was out of a coil spring truck. That's all I know now. Take care everyone. Just wanted to give everyone an update. Pictures are on the way as soon as I get to town.
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Probably a '60-'62 if it's a 3.90 ratio and out of a coil spring truck. I assume you're talking about a 1/2 ton.
Good luck on your test drive!
Steve
'49 3800
'52 3600
'57 3100
Yes it is a 1/2 ton. The ratio is 3.90. I think it is going to work out ok. If not, all I have to do now is locate a better ratio and since the change is already done it will be pretty easy just to change out the third member. Steven
