6 members (Pete O, TrknGMC, Stewart2, Otto Skorzeny, ndkid275, 55shaker), 106 guests, and 2 robots.
Topics128,165
Posts1,057,011
Members48,458
just replaced the clutch on my '51 AD.adjusted the pedal for free play and now won't shift into gear.i did not replace the pressure plate as it seemed relatively new.any thoughts?
Is the throw out bearing on the arm correctly. If so I would tighten the adjustment some more, obviously the clutch is not disengaging.
Tommy
59 apache 1/2t
261 short stepside
i am out of adjustment room
Did you replace the pilot bushing? A too-tight pilot bushing will do that, too.
1956 Chevy 3200
It's possible to put the wrong side of the clutch toward the flywheel. Hope you checked the direction markings on the clutch.
Drew
Being that you are out of room on the adjustment,could you have installed the wrong throw out bearing.Did you set the new one next to the old one to check ht.?
Pete
