| | | Forums66 Topics128,151 Posts1,056,994 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 34 | just replaced the clutch on my '51 AD.adjusted the pedal for free play and now won't shift into gear.i did not replace the pressure plate as it seemed relatively new.any thoughts? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Is the throw out bearing on the arm correctly. If so I would tighten the adjustment some more, obviously the clutch is not disengaging.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2006 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 34 | i am out of adjustment room | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | Did you replace the pilot bushing? A too-tight pilot bushing will do that, too.
1956 Chevy 3200
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | It's possible to put the wrong side of the clutch toward the flywheel. Hope you checked the direction markings on the clutch.
Drew
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Being that you are out of room on the adjustment,could you have installed the wrong throw out bearing.Did you set the new one next to the old one to check ht.?
Pete | | |
