2 members (klhansen, Otto Skorzeny), 86 guests, and 4 robots.
Topics128,130
Posts1,056,712
Members48,454
Which gm engine can I get a used hei distributor out of to fit my son's '53 GMC 228 as his vacuum advance is shot, Thanks
3B Offline
Hy jdzcno, there is no drop in H.E.I. for a GMC 228, it would have to be modified to fit, there is probably a tech tip about doing that. I think the prefered base to start from is an inline six Chevy engine, anything after 1975 should have one, hope that helps.
This is what I've been running last few years on my Chev 235, runs great. Talk to Tom & let him know the application so you get the correct gear to match the cam.
http://www.stoveboltengineco.com/catalog/store/#ecwid:category=361515&mode=product&product=1222040
For Chevy 216, 235, 261, and GMC 228, 248, 270 and 302 engines. Includes new cap, rotor, and OEM GM HEI square coil.
Steel gear is necessary for pre-1954 Chevy and GMC engines with a forged steel camshaft!
BC
1960 C60 pasture art
Thanks emailed Tom. Son just does not have 185.00 as his stipend at the air force academy is not much. I guess he will just have to save up for a while until he can buy new from Tom. Thanks for the help
There are a couple of articles on converting one yourself in the Tech Tips section of this site.
Maybe its a GMC thing, but. If the problem is vacuum advance, and especially if the budget is tight, why not just fix the vacuum advance?
$40 from Jim Carter
regards,
Leon
The truck can and will run without a Vacuum advance...You just won't optimize fuel economy. Cap the line and adjust the timing to a compromise and call it macaroni. The poor running probably has more to do with a vacuum leak than it does with the vacuum advance.
