| | | Forums66 Topics128,105 Posts1,056,552 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | More to the point are the speedometer drives the same, Can you use the 3.55:1 speedometer drive if you change from the stock 4.56:1 to a 3.55:1 rear end, to get a correct reading. working on a 51
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 513600, if we're talking about four speeds I believe the appropriate parts will interchange, but you may have to change both the drive and driven gears, hope that helps. | | |
