4 members (55shaker, 2-Ton, 52Carl, Hawkman), 102 guests, and 4 robots.
Topics128,100
Posts1,056,515
Members48,448
More to the point are the speedometer drives the same,
Can you use the 3.55:1 speedometer drive if you change from the stock 4.56:1 to a 3.55:1 rear end, to get a correct reading.
working on a 51
3B Offline
Hy 513600, if we're talking about four speeds I believe the appropriate parts will interchange, but you may have to change both the drive and driven gears, hope that helps.
