1 members (Bill Hanlon),
48
Mod | | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 20 New Guy | | New Guy Joined: Apr 2012 Posts: 20 | Does anyone know how long a 1963 truck bed is? I also need to know how far from the front of the bed the middle of the wheels are. I am planning on building my 1963 c60 into a real big truck so I am trying to figure out how much frame I need to take out. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Apr 2012 Posts: 20 New Guy | | New Guy Joined: Apr 2012 Posts: 20 | The link to the page that you sent me did not work.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Bill's link works fine. You have to wait a while for it to load, because it is a multi-megabyte PDF file.
| | | | | Joined: Apr 2012 Posts: 20 New Guy | | New Guy Joined: Apr 2012 Posts: 20 | Thanks! that gave me the bed length, but i still did not see how far the frame extends from the back of the cab, or where the wheel is? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | isn't there a wheelbase spec in there? isn't there enough dimensions given for the various models that a little math can sort it out? have you thought how a bed designed for a drop center frame, will fit on a straight channel frame? do you have a bed to use or are you planning to cut up the frame and hope the bed you find later will fit?
Bill | | | | | Joined: Apr 2012 Posts: 20 New Guy | | New Guy Joined: Apr 2012 Posts: 20 | The wheelbase spec wont work because of the difference in the nose. I am building a subframe to mount the bed on Yes I have done the math and figured out my bed length and everything, but no where could I find how far back the wheels are mounted. I think the wheel center should be exactly halfway back the bed but would like somebody to confirm that. Thanks | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Are you putting a pickup bed on your bigbolt? If so how long is the bed (6-1/2', 8' or 9')? I wouldn't cut anything before I had the bed in hand. If you have the bed, it's just a mater of dry fitting the bed on top of your frame until it looks centered over your axle and tires. Then mark it up and start cutting. Mike B  | | | | | Joined: Apr 2012 Posts: 20 New Guy | | New Guy Joined: Apr 2012 Posts: 20 | it is an 8' bed.I will dry fit it but any idea how much bed should hang over the end of the frame? | | | | | Joined: Mar 2004 Posts: 6,212 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,212 | Stand the bed up and measure it...I think it's about 48". Mike B  | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I understand this is a C60? Correct?
Assuming it is the dimenbsionb you want is called the CA (cab-to-axle) and for various bodies is can be different but an 8' body (or bed as you refer to it) is probably a dump body. That uses a 60" CA. That is the shortest CA that was available and still is for a Ford or Ram 350-5500. If it is for a platform body it maybe 9'-10' long. Just depends on the particular application. In 63' a 72", 84", 102", 114" and 120" were also available and probably 138" and maybe even 150". So tell us what the body is and I can steer you correctly. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Dave, he's wanting to put a 60's longbed pickup box on his big bolt Bill | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Long WB pickup bodies are made for a 56"CA.
I re-read his question and still didn't see anything about a P/U body. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | did you read his responses above and other post that I linked? seems clear enough he's trying to turn a 1.5T into a "big" pickup
Bill | | |
