7 members (gswbbc, TUTS 59, jmoore, Brian Moore, tclederman, Steelonsteel, BC59),
82
Mod | | | Forums66 Topics128,031 Posts1,055,435 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | so after all the tuning issues with my holley 390, i think im going to be switching back to my original 1 barrel rochester. the 4 barrel is just too much for my 235. i have put smaller jets and it is still running extremely rich. probably should have just left it all original in the first place. although that 4 barrel does look pretty nice in there. i am looking for some pics of the rochester throttel linkage since I will have to redo mine. will also have to run a new choke cable to it since the holley was electric choke! thanks! | | | | | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | actually i just found some pics from a previous post. any idea where i can find the throttle linkage setup that goes from carb to pedal? thanks! | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Are you talking for Chevy hydra-matic? That is a rare piece. Chevy and GMC are different. I MAY have a couple of leads. Both I am sure will be pricey. Send me a PM when you get yourself prepared for sticker shock. | | | | | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | Hydramatic, I have the part that mounts on block, I just need the rod that goes from linkage to linkage. Thanks! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | old54truckluvr,
You might want to post a few pictures of the what you already have. Th Hydra-Matic linkage is complicated compared to the standard linkage.
Also, the Hydra-Matic carburetor and truck did not have a choke cable nor a throttle cable.
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | Here is a link to the pictures of the link that goes from the bellcrank on side of block up to the carb. It is in comparison to a standard transmission link. The link from the acellerator pedal to the bellcrank is also different but still on the truck and not easily photographed. It too is adjustable but I am going to assume that it did not get changed on your truck going to the 4bbl carb. Tim has a part number fot a universal Camaro rod that is on my truck right now for the dual Carter/Weber carb setup. That is why the link was on parts shelf and available for the photo op. If I were going to try and duplicate the original piece, that universal rod would be a great starting point as it would basically just require the bends. The adjustable end is round instead of square but still closer than anything else I think you will find. http://community.webshots.com/album/583181410LoUAYI?vhost=communityHope this helps you out.(and no, I don't want to sell the rod I am not currently using in case you were wondering) | | | | | Joined: Dec 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 127 | that is definately the piece i am looking for. darn yours isnt for sale!! wonder if anyone else has one laying around for sale? i might even try local hardware shop for some threaded rod and just bend it myself. thanks again for all the help! Here is a link to the pictures of the link that goes from the bellcrank on side of block up to the carb. It is in comparison to a standard transmission link. The link from the acellerator pedal to the bellcrank is also different but still on the truck and not easily photographed. It too is adjustable but I am going to assume that it did not get changed on your truck going to the 4bbl carb. Tim has a part number fot a universal Camaro rod that is on my truck right now for the dual Carter/Weber carb setup. That is why the link was on parts shelf and available for the photo op. If I were going to try and duplicate the original piece, that universal rod would be a great starting point as it would basically just require the bends. The adjustable end is round instead of square but still closer than anything else I think you will find. http://community.webshots.com/album/583181410LoUAYI?vhost=communityHope this helps you out.(and no, I don't want to sell the rod I am not currently using in case you were wondering) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
