4 members (sawdust54, G508, Peggy M, Uncles51), 86 guests, and 3 robots.
Topics128,028
Posts1,055,414
Members48,422
#870126 07/28/2012 2:46 PM
so after all the tuning issues with my holley 390, i think im going to be switching back to my original 1 barrel rochester. the 4 barrel is just too much for my 235. i have put smaller jets and it is still running extremely rich. probably should have just left it all original in the first place. although that 4 barrel does look pretty nice in there. i am looking for some pics of the rochester throttel linkage since I will have to redo mine. will also have to run a new choke cable to it since the holley was electric choke! thanks!
1954 Chevy 3100. Original 235 and Hydramatic
www.cardomain.com/ride/2344117
actually i just found some pics from a previous post. any idea where i can find the throttle linkage setup that goes from carb to pedal? thanks!
Are you talking for Chevy hydra-matic? That is a rare piece. Chevy and GMC are different. I MAY have a couple of leads. Both I am sure will be pricey. Send me a PM when you get yourself prepared for sticker shock.
Greg_H #870260 07/29/2012 1:25 AM
Hydramatic, I have the part that mounts on block, I just need the rod that goes from linkage to linkage. Thanks!
old54truckluvr,
You might want to post a few pictures of the what you already have. Th Hydra-Matic linkage is complicated compared to the standard linkage.
Also, the Hydra-Matic carburetor and truck did not have a choke cable nor a throttle cable.
tclederman #870327 07/29/2012 11:09 AM
Here is a link to the pictures of the link that goes from the bellcrank on side of block up to the carb. It is in comparison to a standard transmission link. The link from the acellerator pedal to the bellcrank is also different but still on the truck and not easily photographed. It too is adjustable but I am going to assume that it did not get changed on your truck going to the 4bbl carb. Tim has a part number fot a universal Camaro rod that is on my truck right now for the dual Carter/Weber carb setup. That is why the link was on parts shelf and available for the photo op. If I were going to try and duplicate the original piece, that universal rod would be a great starting point as it would basically just require the bends. The adjustable end is round instead of square but still closer than anything else I think you will find. http://community.webshots.com/album/583181410LoUAYI?vhost=community
Hope this helps you out.(and no, I don't want to sell the rod I am not currently using in case you were wondering)
Greg_H #870503 07/29/2012 10:31 PM
that is definately the piece i am looking for. darn yours isnt for sale!! wonder if anyone else has one laying around for sale? i might even try local hardware shop for some threaded rod and just bend it myself. thanks again for all the help!
