Hey Guys -
First it what is sure to be many questions about my newly aquired truck. In case you missed it, here's my intro post:
intro post The original ignition key must have broken at some point, because the PPO (previous previous owner) had wired up a toggle switch, with a push button start. The toggle switch turns the truck on and off, kinda. With the switch "off" pressing the start button still causes the starter to turn, but the motor won't light, I would guess no spark. And with the switch "off", the generator light lights up.
The PO (previous owner) told me the alternator was bad, but he gave me a new gm alternator to replace it. I haven't tested it yet (I will tonight) but I wonder if the it's fine, it's just that the wiring is bad, and is sucking power from the battery when it is "off". What do you guys think?
I'm planning on replacing the wiring with a "It's a Snap" or "EZ Wiring" kit, very soon.
Thanks.
