4 members (WICruiser, Napco Man, Oswald, joe apple), 86 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#8698 05/31/2002 4:37 AM
I have a '52 216 in a 42 Chevy P/U. What is the correct timing and firing order. I thought I had it after I already pulled my distributer... but I don't! (I have the timing and firing order for the 235.) Please help if you can. Thanks!
#8699 05/31/2002 4:47 AM
Hello...! Is anyone able to help..?
#8700 05/31/2002 4:55 AM
Oly Offline
I would help, but you already have the correct timing for the 216 and 235- they are the same. 153624 and bring number one to TDC on the compression stroke and you little ball should show in the window. Put number one on the bug and yer a go. If you still can't figure it I will walk you through timing a "disturbed engine".
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#8701 06/08/2002 4:20 AM
153624. try putting it 3 degrees past tdc. then tighten it down. you can always adjust it later.
Where would I be without my trusted shop manual? i'll read it word for word if you wnat..
justin kohut
1950 fleetline/kustom
1950 Buick super (straight eight)
