3 members (Wayne67vert, crenwelge, 1 invisible),
475
Mod | | | Forums66 Topics128,282 Posts1,058,494 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 39 New Guy | | New Guy Joined: Dec 2011 Posts: 39 | Hi all! SO i have a 1bbl carter that i took apart to rebuild, but when i ordered the rebuild kit, the needle turned out to be too large. It was a rebuild kit for a Carter YF, any ideas as to why this is wrong?
- Theres no replacement for displacement.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | you didn't state what model carter you have or what kit you purchased are you referring to the float needle? I use a walker kit from Oreilly Auto ...link... CarbKing also has an excellent kit. Good Luck | | | | | Joined: Dec 2011 Posts: 39 New Guy | | New Guy Joined: Dec 2011 Posts: 39 | I used a NAPA kit and yes, the needle was way to long, and the screw in cylinder that goes around it was to large as well. And I have a Carter YF carb
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Can you post a pic? I have some carter yf pic's in this folder ..link... Maybe you can refer to one of my pic's, if I have one of what you are referring to. | | |
