2 members (Guitplayer, Achipmunk), 61 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#869400 07/25/2012 3:57 PM
Hi all! SO i have a 1bbl carter that i took apart to rebuild, but when i ordered the rebuild kit, the needle turned out to be too large. It was a rebuild kit for a Carter YF, any ideas as to why this is wrong?
- Theres no replacement for displacement.
you didn't state what model carter you have
or what kit you purchased
are you referring to the float needle?
I use a walker kit from Oreilly Auto
...link...
CarbKing also has an excellent kit.
Good Luck
I used a NAPA kit and yes, the needle was way to long, and the screw in cylinder that goes around it was to large as well. And I have a Carter YF carb
Can you post a pic?
I have some carter yf pic's in this folder
..link...
Maybe you can refer to one of my pic's, if I have one of what you are referring to.
