| | | Forums66 Topics128,018 Posts1,055,339 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#86972 09/03/2002 4:51 PM | Joined: Jun 2002 Posts: 19 Member | | Member Joined: Jun 2002 Posts: 19 | Just finished a complete rewire of my 53. The PO had attempted to convert it to 12V but basically nothing worked except ignition. I have a 5-wire connection from the alternator (early 60's?) to the regulator and when I hooked up the new wiring harness, I left the four wires from the alt to the reg alone. I connected the big red wire to the output? term on the alt and cut off the 2 wire plug from the new harness. I connected the remaining wire to the fifth wire on the regulator and fired her up. Everything seems to work fine, except now I have a fairly loud humming noise in the alt. Maybe that's normal when it's actually working 'cause I don't think it did before. I checked the voltage at the output of the alt and it looks to be about 14V. Is this OK? Or is it too high. All the new guages work now and the Ammeter gage shows charge when running and discharge when lights are on w/ engine off.
If you think you can or if you think you can't, either way you're right.
#86973 09/03/2002 6:48 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Don't know about the noise (it should be quiet), but you can set the output as high as 14.8 volts.
Fred 52 3600 69 C-10
#86974 09/03/2002 10:57 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | You could have a bad bearing. Use a large screw driver to listen to the bearings. The 14v is about right.
if it dosen't need fixed, break it
#86975 09/03/2002 11:25 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Where should you put the screwdriver? | | |
#86976 09/03/2002 11:40 PM | Joined: Sep 2002 Posts: 158 knuckle head | | knuckle head Joined: Sep 2002 Posts: 158 | The alternator hums when it doesn't know the words.Humming may be a result of normal high output due to a heavy load.An alternator with a bad diode will hum.If one diode had failed, the volt meter could show 14 volts, but the battery will eventually discharge. | | |
#86977 09/04/2002 2:34 AM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | Where should you put the screwdriver? Use the large(long) screwdriver as a stethescope.You can us a long stick as well.Put the end of the "stethescope" at the rear bearing area and the front area as close as you can to determine the noise.Pot your thumb over the end of the stick and your ear against your thumb.Check other areas to compare noise /sound differences.
