| | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2000 Posts: 19 New Guy | | New Guy Joined: Jul 2000 Posts: 19 | ...on a 235 sacrilege? With the cost of fuel and the lousy efficiency of the Rottenchester, I'm considering the swap.
I'm looking to keep the manual choke, so which 94 would I need? And does the 3-bolt Holley just slip right on my manifold, or is there a hoop I need to jump through?
Thanks for helping an old idiot who only knows enough to like his 55.1 3100.
| | | | | Joined: Feb 2004 Posts: 29,783 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,783 | You'll need an adapter to mate the Holley to the Chevy manifold. The most common 3-bolt Holley carb was used on a 239 cubic inch flathead V-8, so the calibration should be pretty close. It will have a 15/16" venturi diameter. Watch out for the slightly larger carb that was used on the 55 Ford 272 engine- - - -it has 1 1/16" venturis, and it will definitely create a flat spot on acceleration. Jerry
| | | | | Joined: Apr 2001 Posts: 268 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 268 | You might look into a Holly 660A1 They were on the 52-53 GMC, may be later 302s. That is what my 53 GMC 454-30 has on it.
It is a 3 bolt flange setting on some kind of adapter.
Dance like no one is watching, Sing like no one is listening, Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420 1948 GMC FC253 1t Factory 80"x9' Flatbed Dually 1948 Chevy COE 2 Ton 8'x15' Flatbed 1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist 1953 GMC 454-30 3 Ton Cab and Chassis 1942 Clarkator 6 MILL-44 Heavy Aircraft Tug 1942 Ford (9N) Moto Tug with 1/2 yard Loader 1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The GMC Holley has the large venturi like the 55/56 Ford had and it will stumble during acceleration. The 239 Ford is about the correct size but it will be designed for the Load a Matic distributor which means it will have port vacuum. You can either run a distributor with no vacuum control or you can convert the port vacuum to manifold vacuum. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The Holley 1bbl carb was used on several Ford engines through the years. Ones from either the 200 or 250 inline six work with a bit of adaptor and linkage mods. Steer clear of the ones with the clear glass on the float chamber as they tended to leak. They are a very squat carb so used them where height clearence was an issue. I can't remember if the 240 had a one bbl but none of them gave much carb problem.
Evan
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Why not use a 68 up Roch. Monojet. It will be a simple swap & they have good fuel metering & can be taylored to the engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
