| | | Forums66 Topics128,169 Posts1,057,035 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | is there a diffidence between the two? thanks for any input! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy drew_vigil, other than one having an "a" that the other one does not have, I don't know. What exactly are you asking about? What do the alpha-numeric numbers represent? | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I have not seen the -1a casting but it must have something to do with the series. It's still a GM. Just when I thought I knew almost everything about these units I picked up a Chevy/BW OD with a R10K-1 casting #. It has a 4 bolt side cover, a 1964 date code with the rear mount pad. I'm going to tear it down and see if anything is different. Fred
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The BW OD units are all very similar. I have seen parts from a Ford BW used in other OD units. If its working, I sure wouldn't tear it down to see what the difference is. If it is a 4 bolt cover, the front is a Muncie. I don't see what difference it makes what the casting number is on the OD unit. | | | | | Joined: Oct 2011 Posts: 206 Shop Shark | | Shop Shark Joined: Oct 2011 Posts: 206 | I HAVE ONE OF EACH INFRONT OF ME, THE INPUT SHAFT ON THE 1A DOSENT TAPER DOWN, BEFORE THE RETAINER LIKE THE R10H-1. tHAT WONT BE A PROBLEM AT ALL WILL IT? | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Many of the internal parts interchange on the BW units such as blocker rings, planetary units and roller clutches. The parts that do not interchange are specific to the OEM such as housings, mainshafts, etc. The R-10K unit that I have is here for repair. Initial inspection reveals that it is the same as every other GM OD I have rebuilt over the last 40+ years. I had not seen the K designator before or not paid attention to it. The solid shaft on the clutch gear is probably a Warner replacement part. There is a GM oddity out there that was used in 64-65 in a Chevelle. It uses the same BW unit but the mainshaft and all the internal gears have a different pitch. None of these parts will interchange with the conventional SM318/319 gears. Fred
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | It turns out that the OD gear box with the R-10K-1 designator is somewhat different. It has a shorter spedo housing & gear, casting for a rear mount, and a fine spline output shaft (like a TH350 or powerglide). The main differences are the internal gears in the trans itself. It appears to be one of these odd units as none of the regular SM318 gears will interchange. It could be expensive to rebuild as it needs a cluster gear & a L-R slider. I usually pick up regular 3 speeds to use for parts but they won't work for this one. Fred
