| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I live near Denver, let me know the details. Also, what frame is being used? COE's most likely use stock frames, just add an updraft carb, different exh. manifold, riser brackets on rear and front of cab., different shift rod, so plan on including those items if using stock frams.
