3 members (IHPWR, Otto Skorzeny, WICruiser), 85 guests, and 1 robot.
Topics128,029
Posts1,055,417
Members48,422
#869031 07/24/2012 8:06 AM
I'm looking at a pair of seats - Q: One bottom appears to have a sliding track while the other has direct mounting brackets
Pics: http://tinyurl.com/LarryBears55
Can I presume that the slider is the driver's seat and the other is passenger? What type of hardware was used on the floor?
Thanks!
Larry
Larry Bear
55.5 Chevy 3100 Panel
Larry,
Your title says AD (Advance-Design?) Panel Seats, but it looks like you are referring to a 55-2nd series panel?
Is that just a typo-error, or will an A-D panel's seats work in a Task Force panel?
tclederman #869054 07/24/2012 10:13 AM
Hi Tim, others here have told me that the AD seats were carried through to later years. I believe the seats in the photos are from a 49 or 50 Chevy panel. My truck is a 55 1/2.
Larry Bear
Larry Bear #869070 07/24/2012 11:02 AM
Larry,
If no one responds by next week, I'll be back home then and I will check the set of 1953 A-D panel seats that I have in storage.
I think the sliding track would be driver's and the passenger seat pivoted towards the dash with a non-sliding/non-adjustable floor mount.
If someone with a 47-55 panel responds regarding how the two seats are attached, would that help? Or, do you want a response from a Task Force panel owner?
Larry Bear #869073 07/24/2012 11:11 AM
the one you picture with the sliders is [almost] the same as the 3 seats I have/had from different TF panels, drivers position - the one without appears to have the mounting for tipping forward for the passengers side, but I'm not sure if the [optional] TF passenger side seat was mounted exactly like that
Flxible #869088 07/24/2012 12:15 PM
Thanks guys. I know seats are hard to find so although I only need the passenger side I think I'm going to bite the bullet and, even though the driver's seat has been cut up, buy both of them. Maybe I'll install a third jump seat in back. LOL
Larry
Larry Bear
Larry Bear #869318 07/25/2012 10:08 AM
Hi Larry, The tipping seat for the passenger side is exactly like what is in my '56 Panel. If you don't have the lower half of the passengers side mounts, they should be easy to make. The driver's side is different or missing parts compared to the two pair I have. The front of the drivers side mount comes down from the rail 3-4 inches and turns out to either side, kind of like an up-side-down "Y," while the rear is more nearly a strap on either rail. There are 2 bolts per corner on the drivers seat that attach to captured nuts on the bottom of the cab floor. Sorry I don't have any pictures.
best wishes,
Les
Roadmarks #869361 07/25/2012 1:28 PM
Thanks Les! The guy selling them is asking about $250 shipped. Steep but then again, I haven't seen any others out there. Larry
Larry Bear
