7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel), 94 guests, and 3 robots.
Topics128,048
Posts1,055,663
#868358 07/21/2012 5:48 PM
This has got to be an easy one. 1948 Chevy, restored and rewired before I bought it.
My headlights worked fine. Brights and low beams.
Then the low beams went. Both Land R. No problem, I rarely drive it at night, and the hi beams ain't that bright anyway. Now, no hi beams. The gauge lights work, and the dome light works. Fuses are good. I replaced one headlight, no good.
Where should I go next?
Who owns this car with the peace sign, mag wheels, and 4 on the floor?
Dude- 1948 Chevrolet Thriftmaser 3600
https://i.imgur.com/NN2ehrsl.jpg
Floor switch.
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
You should get out your meter and wring your wiring.
Cletis #868771 07/23/2012 10:15 AM
Without a meter to test, I'd check the connections at the terminal boards and the wiring for frays/grounding where it passes thru the fenders and into the buckets. If that stuff is all good, replace the floor switch. The switch and sockets are cheap enough and available at most local auto parts stores.
Randomly replacing parts is no way to troubleshoot electric systems, or any other systems for that matter. You can get a multimeter for under $20 that is adequate for troubleshooting the wiring on these old trucks.
Do it right and you only need to do it once.
^ Agreed. I always go thru everything with a multimeter first. Given what he's already done and how he said the lows went then the highs I think its safe to say the switch is probably the culprit and should be the next item taken into consideration.
Originally Posted by Tom R
Floor switch.
Ding Ding Ding!!!!
First post!!!
New floor switch from FLAPS for $6.50 and all is well!!!
Thanks all.
thumbs_up
1948 Chevy 1/2-Ton
U
U Offline
i will have to try that one both my headlights have stopped working when they were fine a few weeks back.
The multi meter is a pretty basic must have tool. I keep one in the dash.
Where on the truck is there a "terminal board" ?
1951 1 Ton Completed
On the inner fender under the hood about a foot from the front.
