0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I was doing some searching the internet looking at info on spray painting and found an article that mentioned Gibbs Penetrating Oil. The guy was working on a project and wasn't going to be paining it right away, but was down to bare metal. He used something called Gibbs to keep the rust away. He stated in the article that you need to prep the metal when ready to paint, but that the oil did not affect the paint, since there could be some in a seam or whatever. Anyone here ever used Gibbs or know where to find it? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | www.getgibbs.comIm on my 4th can,,it works where others dont. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Only over the internet? Has anyone had experience with painting over it?
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, it's mostly an online thing but some shops have it, especially motorcycle shops and gun shops .... it is good stuff and seems to act like a rust converter, I got a couple cans and have used it as a rust preventer in hidden areas as well as removing rust from chrome - haven't painted over it but I don't see why it wouldn't work after normal prep steps .... there's someone Lower Mainland that sells it, but I've misplaced the name right now, you might find out at the Gibbs siteBill | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I have used it and it seems to be good stuff. I bought it on line from the manufacturer. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I used Gibbs to protect my step side bed after I stripped it down to bare metal.
It protected the metal for 3 months, then I simply wiped it down with xylene before priming the metal.
I still have some Gibbs left over and use it just as you would use WD-40. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Dang, sounds good. I wonder why they don't sell it at your local neighborhood parts store. Guess I'll go online. I saw they have a Canadian page too.
A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If you're looking to protect metal prior to painting there are probably better products that are actually an aid to painting and not necessary to remove like you would an oil Picklex is one http://www.picklex20.com/Grigg | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | If you're looking to protect metal prior to painting there are probably better products that are actually an aid to painting and not necessary to remove like you would an oil Picklex is one http://www.picklex20.com/Grigg Picklex is not compatible with some primers. It's NOT compatible with etch primer, for sure. I used it on my bed pieces before putting them into storage. Other Bolters had cautioned me against it because of known incompatibility issues, yet I know that some Epoxy primers will work with it. I'd say you should apply epoxy primer to your bare metal ASAP. If, like me, you can't do that, then Picklex is one of many options that will work but I'd first make sure it will not cause adhesion problems with whatever primer you plan to use. Apparently, epoxy primer is fine as long as it does not contain any acid. I have the MSDS for Picklex if anyone cares to read it. Just send me a PM. You can find out a lot more about Picklex by visiting this forum page. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Good to know! I didn't realize it only works well under some primer and not all. A little research prior to using it with any paint system is definitely in order.
Grigg | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Many years ago auto supply peddlers who called on us had Gibbs. It was good stuff. I don't remember how many years it has been since guys peddled stuff like Gibbs and Bowes Patches etc. I Didn't realize it was still available online. | | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | I have used it and like it, but everyone has their own preference for penetrating or other lubricants. I bought mine from http://www.gibbsbrand.biz/index2.html When I bought, they had a policy of price matching and Billy Grubbs was pleasant to deal with. I will need to get more soon. | | |
