1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#86871 03/14/2004 5:58 PM
anyone out there knows where i can get / copy /look at
wiring diagrams for a 63 chevy truck - i just got mine
and i am tring to do as much as i can myself - trying to
avoid the expense of new harness - thanks .
jsalchevy63
#86872 03/16/2004 7:55 AM
I didn't look for it here but you might give it a try. on line manuals They seem to have a lot of information. Also check the 60-66 web site here in the links section. Joe
#86873 03/17/2004 5:22 AM
THANKS JOE FOUND SOME DIAGRAMS I CAN USE wink
jsalchevy63
#86874 03/22/2004 5:12 AM
WAS ABLE TO GET PARK LIGHTS TO TURN ON AND TURN OFF
WHEN I PULL SWITCH TO TURN ON HEADLIGHT- THE TAIL LIGHTS TURN ON ALSO AND EVEN WHEN THE SWITCH IS IN
PARK MODE . TAILLIGHTS ARE TWO CONTACS AND TWO
FILAMENTS - BRAKE SWITCH APPEARS OK - BRAKE LIGHT
WORKED ON RIGHT SIDE BUT NOT THE LEFT - I MESSED WITH
THE WIRING AND NOW I HAVE NO BRAKE LIGHTS AND I HAVE NO
CLUE WHAT HAPPEND . ANYONE OUT THERE WITH ANZWERS -
I AM ALL BRAKED OUT :confused:
jsalchevy63
#86875 03/22/2004 6:20 AM
You may have wiggled a wire that is bare and it touched metal which blew the brake fuse on the fuse panel.
Joe
#86876 03/22/2004 6:45 AM
Boy you don't ask for much. wink How badly has the wiring been molested by POs? Sometimes the easiest thing to do is eliminate all but original wires, might not be possible. Were you able to get the factory wiring diagram? You have a 12 volt test light too? That said.... btw I have a 63 and factory diagram. Email me direct and we'll see what we can work out.
Larry
68 C20 327 daily driver
63 C20 292 Camper truck
65 C10 ? Custom Cab AC,PB,PS,$flasher
I don't own a vehicle that isn't old enough to drink.
#86877 03/22/2004 1:02 PM
well i took another look - coming fron the engine firewall
are three wires colors are what appears black - violet - pink
and the drivers side taillight one white one black and the
other one red and one black - what a mess - waiting on
diagram but taking to long - the wiring by far is ok - there
is a lot of colors under dash - but those wires leading to
the back might have to be replaced , :mad:
jsalchevy63
